![]() | Home > General (L494) > On Board Trouble codes |
So now you know there is a light problem with the turbo what are you going to do with it |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Very strange to see such unbalanced airflow readings between the two MAF sensors. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 ![]() ![]() |
Dealer is replacing the turbo when it gets here but to day 2 new faults HDC not available gearbox fault?? So the list gets bigger seat does not work Turbo and now this! Looks like my fears about Range Rover reliability are coming home ! M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
You can only wonder if these faults are related, it will be good see if the turbo fix resolves your main issue. 2017 MY17 SDV6 SE |
The gear box and HDC alarms are often a sign of a battery that isn't fully charged. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tim the faults turned up after a long drive so I would think the battery OK. The car gets mainly long journey's so being a new vehicle I would mot think battery is an issue. The car is in next week so I will know the deal after the fix. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Battery earth problem then? 2017 MY17 SDV6 SE |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
I had (not in the RRS) an engine light come on associated with a slight hesitation just below 2000 rpm. Oscilloscope on the wires from the HEGO sensors showed these would wander between limits until staying too long off-scale when the ECU decided something was wrong.
I am hoping that this isn't a current issue but a dud part issue. The fact it is turning up driving and more so when under load hopefully points to the actuator . The other faults that suddenly turned up ? They have not been back and perhaps this was just driving into the car park and some sensors got confused. Very disappointing that these issues turn up reminds me of Italian motorcycles that I have owned, manufacturer had no idea when it came to electrics. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
No codes now, day 1 running after repairs so I will keep the app running for awhile to check, but as for now no active fault codes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
3 days no codes and couple of 100 K's covered. Got into the mud today and even the slippy dirt could not make the car chuck a code. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
That is good news, it's difficult when you loose confidence in a car and can take ages to re-gain that confidence after an event. 2017 MY17 SDV6 SE |
Mat had the front disc's done at the same time and this worked out very well. The parts supplied by local company. $75 per rotor plus pads and sensors were fitted by the Dealer for $165 which was worth it for me. Having a cheaper alternative to OME, these parts were OME except for the Disc's, is great. I was going to keep the old disc's and get them skimmed but for a saving of $75 dollars I think I will just replace each time. I have yet to get spare fuel filter but will try the place I got the disc's from. The dealer has been great to work with all issues now resolved, my seat works the way it is supposed to and parking sensors the first issue are now working full time in the front.
Bails, it feels great to have a dealer interested and proactive in your ownership experience. I've only just received my invite for the driver experience day, 4 moths after purchase.. I look forward to that! They had a glitch apparently, at least the RR hasn't ... yet. LOL
