Home > Maintenance & Modifications > Poly / power flex vs Rubber
nah33m
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I have had my car in and out of dealers and Indys for bushes over the past year or so, it is costing me.
I am driving a 2008 Range Rover Sport HST V8 3.6.
It seems like the bushes are just too weak for the job, I don't off road and I don't thrash it around, my roads are generally good and I do low mileage so it is very annoying.
My ARB have been replaced twice and my lower arm bushes are starting to go again second time in less than 18 months.
I want to go down the poly / power flex route for everything that's includes all upper and lower arm bushes and ARB.
I did this to my E46 M3 and although the ride became very stiff it was precise and firm, it also they never required replacing again!
What I am looking for is some feedback on the reliability from forum members and if there is any additional squeaks, bangs, knocking noises that maybe introduced and why this would happen, I am looking for a very firm but quiet experience.
I rather not put rubber bushes back on if I can avoid it at all.!
The lower and upper arms are straight forward so not so worried about changing them myself.
However I am not so sure about the ARB as it has the dynamic control, few posts say it's a dealer job, but I have seen a few saying it can be done by yourself. I would rather tackle the job myself so if you can point me to any posts or links that can walk me through the process that would great.
Thanks in advance
Post #527022 Mon May 29 2017 9:14am
nah33m
: BUMP :
Anyone got any information?
Post #527238 Wed May 31 2017 1:24pm
Paddi
If you search the Disco 3 website you'll find a lot of posts regarding the pros and cons of polybushes. Doesn't seem to be a consensus view; some like them others say they are too harsh.
Have a good look around on Advanced Factors' website as they offer bushes from Superpro and Bearmach in addition to those you mentioned.
Your ARB bushes should be lasting better and I wonder if your garage has fitted the correct updated bushes and clamps. It is definitely possible for a determined DIYer. Search the site and you'll find a couple of threads with some useful tips. Have to confess have not done mine myself as they went in winter and I didn't like!e the idea of freezing my @rse off lying under the car in February. 2008 MY Java Black TDV8 HSE
Post #527255 Wed May 31 2017 4:50pm
Tim in Scotland
Are you running on wheels/tyres bigger than 20"? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527265 Wed May 31 2017 6:05pm
Pufftmw
I've fitted front Powerflex ARBs and I've had no problems so far. Is the ride harsher? Maybe but I don't notice it. I do think its worthwhile as I've been through 2 sets of front ARBs previously.
Had the lower arms done at the same time with OE and so far I've had no knocking noises, so that's brilliant. I do get some creaking going over ramps though, so not sure if that is the arms, ARBs or something else Rolling Eyes
Post #527278 Wed May 31 2017 8:21pm
nah33m
Yes I have 22 inch onyx alloys with 285/35/22 rubber bands on them so it's a back braking ride
Post #527304 Wed May 31 2017 11:12pm
Tim in Scotland
The suspension, transmission and drive components were only designed to take 20" and if the dealers found you had fitted bigger they voided your warranty on L320's. My L494 RRS2 has OEM 22" wheels as they are an option on the newer cars. It could be the big wheels that are causing your problems, especially if the car has been running on them for a few years. TDv8's have a history of premature wear on front suspension components even with OEM 20" wheels/ tyres 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527309 Wed May 31 2017 11:32pm
nah33m
Do you have the active anti roll bar? Mine is a V8 3.6 diesel so want to be sure if it's the same as yours.
Would you consider changing the lower and upper arm bushes to poly?
It seems like because of my massive wheels they are placing extra stress on the bushes so probably need something a little more durable to support them.
Post #527330 Thu Jun 01 2017 7:38am
Pufftmw
Yes, I have ACE
I've not considered poly bushes for the arms at this stage. I think I discussed them with my garage and the consensus was that they weren't needed but I'm happy to reconsider. I do razz my car on bumpy country roads, drag heavy trailers and venture gently off the beaten track, so I will keep an eye on what happens.
Not sure about the difference in 22s to 19s or 20s but reducing unsprung weight will make the ride better and reduce wear. Whether you would wish to poly bush and keep 22s, thus increasing the harsh ride on a ride already harsher than standard, I guess is up to you Smile
Post #527342 Thu Jun 01 2017 10:28am
nah33m
thanks guys for the feedback, i am used to BMW M sport firm suspension setup so sitting in a RRS is like a magic carpet even if its slightly stiffer.
I am leaning towards Poly's at the moment just because i think they will better suit my needs, and if i can change them myself then i can always change them back to OEM without hurting my pocket too much Thumbs Up
I have found this video regarding changing my ARB myself, has anyone used this as a guide in replacing theirs?
http://www.roverparts.com/resources/videos...ver-sport/
Seems straight forward even for something which has an Dynamic Stability control like my V8 HST.
But it is over the pond so could be something that is different for us in the UK.
Can you let me have your thoughts
Post #527350 Thu Jun 01 2017 12:35pm
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi , the video link you watched is for rear ARB bushes which is easier than front . I'm considering changing to poly front bushes with the upgrade bracket . My local Indy thought it was a waste of time replacing my front rubber bushes as my anti roll bar is weeping slightly onto one of the bushes and suggested this would ruin the bush within 6 months . Cost of replacing front anti roll bar with ace is £1500 !! So in the mean time untill I can afford to get that job done I thought changing to poly bushes would help as the oil may not penitrate the bush . It's a job I intend to tackle with a mechanic friend up on a vehicle lift
Post #529486 Mon Jul 03 2017 6:46am
geoffsnook
A few people do say that super pro bushes are a little softer so better than poly busshes Thumbs Up
Post #529488 Mon Jul 03 2017 6:50am
One issue is some garages tighten the arm bolts (the ones that attach the suspension to the chassis) when it's jacked up with the suspension dangling. The problem with this is that when the car is on its wheels on the road, the bushes are already stressed - they're effectively at more than full compression when the car is stood doing nothing. So they don't last very long.
The bolts should be tightened when the suspension is at the correct ride height. The bushes then are correctly loaded and last longer.
Remember: the suspension has much longer travel than a normal car's so the bushes need to be correctly set up. 2012 SDV6 - it's missing a couple of cylinders
Post #529502 Mon Jul 03 2017 1:05pm
Johnski
All LR genuine parts are covered by a two year warranty, and I didn't even have to pay labour either, could be cheaper using LR service centres, if you are having problems. John
Post #529508 Mon Jul 03 2017 3:09pm
