![]() | Home > Detailing & Car Cleaning > Getting dead bugs off the windscreen |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1862 ![]() ![]() |
Not so much for the screen, but the bodywork.
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
I use halfords foaming glass cleaner, let it sit a little bit, then scrub with a microfibre, gets the worst off day to day.
Some companies do specialist bug removers like this.
The links are for the same product!! 2023 P440e SE Dynamic on order -cancelled
Don't know what you're talking about |
My mistake.... |
I might try that on the screen, as it is a nightmare when we drive down through France.
I apply it a lot less frequently than I really should |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 ![]() ![]() |
Jim, absolutely spot on. I wish I had thought of applying something before the Bank Holiday weekend. I drove to Monte Carlo and back and the front of my RRS is completely covered - you can hardly read the registration number! Jas Current RRS: MY18 SVR Previous RRS: MY15 RRS 5.0L Autobiography |
Actually this just reminds me ... when we drove to France last month, upon arrival I found my headlamps (which I leave on auto) were constantly on even in bright sunlight. I assumed the external light sensor was covered. Used the washer/wipers a bit aggressively and the lights turned off. Either a strange coincidence or more likely due to bug removal. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
OK, I will give it a go on the next trip. |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
I have just used Autoglym Active Insect Remover this morning just to enable a drive with full visability. Worked very well on both bodywork and windscreen following 3.5 day drive from Lagos in SW Portugal back home to Inverness. I wish I had had it before I embarked on our travels as it was a real nuisance on the journey and the washer fluid did little to help, merely smearing the detritus across the screen!
Products like G5 or RainX are worth it even just for water repellency from windscreen. I don't need to use my wipers when driving above 35/40 mph as the head wind drives up rain water in straight lines, efficiently clearing the view. When I do use the wipers at lower speeds, the operation is very smooth and smear-free. I am on my original set of wiper blades after 15k+ miles/nearly 21 months and never had to refill washer fluid (unless the dealer topped up on one of the several visits). Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
