![]() | Home > Technical > Air con and engine revs |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Probably doesn't increase the revs if the engine is warm |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
Good point, never thought of that. Just was a bit of a shock when I took my foot off the brake and it reversed up my drive without touching the accelerator. Doesn't normally do that as its on a bit of a hill, but you are probably right. |
Tried it this afternoon from cold, and it has behaved itself. No increase in rpm at all, Maybe its just one of those range rover things. |
wonder if its a low voltage problem.
What was the ambient temperature?
Battery is new, and haven't had any other power issues. Temperature was 28 degrees, I have never noticed anything like this before on any of my other cars, or on this before. But I only drove it occasionally before I took full ownership of it. Its been fine ever since, but temperatures have been cooler. |
