Home > Technical > Air con and engine revs
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
My air con was re gassed in January this year and has worked faultlessly since. System pressurised ok when it was done. Yesterday when I switched it on the engine revs at idle increased with every click of the blower switch. With the heater on full it was idling at 1100 rpm. I drove to the shops and tried it again, it was the same. Came out of the shops it was the same again, drove home tried it again and it was back to normal, turn the blower up and cold air but no increase in rpm.
Any ideas what can cause this? Is something starting to fail? Any input would be appreciated.
I have no fault codes present
Thanks in advance
Post #526891 Sat May 27 2017 9:33am
d-9
Probably doesn't increase the revs if the engine is warm
Post #526895 Sat May 27 2017 11:03am
squizzel
Good point, never thought of that. Just was a bit of a shock when I took my foot off the brake and it reversed up my drive without touching the accelerator. Doesn't normally do that as its on a bit of a hill, but you are probably right.
Post #526902 Sat May 27 2017 12:17pm
squizzel
Tried it this afternoon from cold, and it has behaved itself. No increase in rpm at all, Maybe its just one of those range rover things.
Post #526913 Sat May 27 2017 5:10pm
wonder if its a low voltage problem.
check the voltage when you are doing this.
Post #526915 Sat May 27 2017 5:24pm
Disco_Mikey
What was the ambient temperature?
On very hot days, the PCM will increase the engine RPM to maintain the required cooling inside the car Thumbs Up
I have only noticed it in 30+ degrees, in my car, but the AC is normally quite cold anyway
Post #526916 Sat May 27 2017 5:35pm
squizzel
Battery is new, and haven't had any other power issues. Temperature was 28 degrees, I have never noticed anything like this before on any of my other cars, or on this before. But I only drove it occasionally before I took full ownership of it. Its been fine ever since, but temperatures have been cooler.
Post #526929 Sat May 27 2017 8:24pm
