![]() | Home > Technical > Air conditioning |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
If the a/c is regularly used all year round, to keep the carbon shaft seal within the compressor oiled and expanded, then the system should remain sealed and never need recharging unless a component is damaged or breaks.
In modern cars AC/Climate Control hardly uses any power unlike in the old days, also leaving it in auto is much better than switching it off. In winter the RRS system will also give you warm aircon when needed which helps reduce issues with condensation/ damp inside the car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
My air conditioning isn't getting cold in this weather
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
yes you need the dash vents open. |
Yep, leave it in auto all year round |
I will have the system re gassed and checked
Sport Dog Member Since: 15 Apr 2017 Location: Dorset Posts: 11 ![]() ![]() ![]() |
I've got the same problem as you, Cosmo.
Had mine gassed last Friday as it was not working and managed to get out nearly 790 grams of gas lol so put 600 grams back in and air-con started working really well but tried it over the next few days and does not get cold at all so if any one has any ideas as where to go next |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Mine is not as cold as it normally is and also there is a clicking noise from the front of the car which i haven't noticed before! SVR 2018 in Santorini Black. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I've had my car just over 5 years and its been absolutely fine up until a couple of weeks ago and a sweaty drive back from Wales - likely coincided with hotter weather (25 deg o/side). Popped into KwikFit and its all working lovely again |
Does the clicking noise change with RPM or does it stay more or less constant. ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Tim in Scotland is 100% correct, Modern systems do not cost that much to run, if you are turning it off to save a few pence, then best sell your Sport.
Leaving it in Auto is also good for the various electronic black boxes dotted around the interior, the audio and satnav - the RRS system also de-humidifies the interior so they do not get affected by condensation/ damp which will eventually happen if you switch the system off. There is a big problem now in L322 FFRR's where the owners haven't run the Climate Control for whatever reason - the sat-nav and audio systems in them are mounted behind the side panels in the boot area and it is a known problem that if the Climate Control is not run all the time there is quite bad condensation forms behind the panels, drips down onto the electronic units and they go bang. Apart from running the climate control all the time the "Fix" for this in L322 is a recycled ice cream container that fits neatly over the top of the units to prevent water drips getting in. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hi SRE as it just started i,m not sure and have not used it since. Its going in monday to get checked , they think it just needs gas .
