Home > Technical > Tdv8 egr blanking
S16ARV
Tdv8 egr blanking
I've just brought a 2008 range rover sport tdv8 and the other day had the engine management light come on. It gave me P1335 and P0405 egr codes. I've just ordered an egr blanking kit but can these be blanked and removed with no problems and if so can anyone recommend somewhere to get it done
Post #525243 Thu May 04 2017 10:15am
DrRob
Call Alive Tuning or Bell Auto Services for definitive answer but my understanding is you cannot blank a tdv8....keep your receipt Whistle Visitor from fullfatrr.com
Post #525253 Thu May 04 2017 1:11pm
GodivaNige
Someone posted a while back having had his TDV8 EGR's successfully blanked by a company in Bristol, working out cheaper than replacing the EGR's. The company are apparently very experienced at doing this.
I will try and find the post but hopefully the member will see this and give you the right info.
Post #525272 Thu May 04 2017 3:26pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Yes it can be done But can't be reversed 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #525290 Thu May 04 2017 5:28pm
ShooterNeil
Bodsy can do it for you 61 AB 5.0 supercharged rocket
Post #525291 Thu May 04 2017 5:30pm
DrRob
I stand corrected Thumbs Up Visitor from fullfatrr.com
Post #525368 Fri May 05 2017 11:17am
d-9
I also read on here that's it's not recommend for the tdv8, but the person saying that didn't give any more info on why not. The guy who had them replaced did say that his fuel consumption had improved a lot too
Post #525388 Fri May 05 2017 1:31pm
S16ARV
Hi thanks for the replys. I've had the egr's mapped out now and I've just fitted the blanking plates. The car runs much better now and no lights on the dash. I have been told that the butterfly valves need removing now though but can't see how the butterflys come out. Has anyone else done this or will I be ok leaving them in?
Post #525602 Mon May 08 2017 3:15pm
Past91rrs09
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
S16 ARV , did anyone get back to you about the butterfly on a tdv8? As I'm also trying to find out, seem to find a lot about the tdv6 but not the tdv8
Post #531879 Tue Aug 01 2017 8:38pm
Bodsy
Site Sponsor
You need to snip or cut out the butterfly valves. Remove the unit and do it off the car is easier and less risk of bits of plastic floating in the engine!
There is NO metal shaft going through the inlet, it's all plastic. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #531900 Wed Aug 02 2017 8:55am
PaulMason
Why ds the butterfly need removing...and anyone have a photo of it ?
Post #581808 Mon Jun 03 2019 5:08pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
I have mine blanked on MY 08 TDV8
I have mine blanked on MY 08 TDV8 Without any problems Thumbs Up Very Happy MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
REAR 9 INCH TOUCH SCREEN HEADREST TV SCREENS, WIRELESS HEADRESTS, IN-CAR WIFI MIRROR BOX FOR WATCHING INTERNET TVIE BBC I-PLAYER ETC... FROM ANDROID, WINDOWS AND IOS PHONES ON THE GO ON ALL SCREENS
Post #581812 Mon Jun 03 2019 6:31pm
PaulMason
So Ive fitted my blanking plates and mapped out the EGR's, I haven't removed the butterfly's as I'm not convinced they need to be. So far less smoke and spool up seems a little faster, but that's all I could say. Took about 45minutes to swap out.
Post #581834 Tue Jun 04 2019 3:26pm
MikeTDV8
Belgium 2008 Range Rover Sport TDV8 HSE Lux Alaska White
I’ve had the EGR’s blanked including a software adjustment on my MY 2008 5 months and 20.000 km’s ago, the car runs great.
Job was done by KC Performance in Helvoirt (NL)
Post #584309 Mon Jul 22 2019 2:54pm
