Home > Technical > Faults after recon gearbox and new torque converter
Past91rrs09
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Anyone know why I'm getting the faults after gearbox and torque converter
Post #525408 Fri May 05 2017 6:30pm
Disco_Mikey
Take it back, let the repairer sort it Thumbs Up
Post #525415 Fri May 05 2017 7:46pm
Past91rrs09
Just get some sort of idea as have spoke to them but saying could be the Tom but the tcm is showing as normal just ever other module can't communicate , possible broken wires or bad earth/live
Post #525427 Fri May 05 2017 8:31pm
Disco_Mikey
Would be handy to know what the actual issues you are having are...
Post #525433 Fri May 05 2017 9:23pm
Past91rrs09
Problem is that not all the time but every so often then car seems underpowered the v8 rumble from exhaust becomes faint and the gearbox seems to hold gears longer e.g. Up to 4000rpm before changing up also mpg has gone from 25 to 18 ? Only fault that did show on dash was dsc warning stop happened twice both times when going round corner slightly faster than normal I know sounds stupid but one second the cars spot on puts you in your seat next gutless
Have just been told that faulty battery can cause these errors?
Post #525437 Fri May 05 2017 10:07pm
