Home > Technical > Slight misfire |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
You timing chain guides may be worn and allow for some chain slack on idle. Regards etc.,
Fri May 05 2017 4:33pm |
Nothing to indicate that to be honest |
Fri May 05 2017 5:16pm |
The simultaneous lean and misfire codes happening no matter if you run LPG or petrol, may indicate an issue with the timing chain (guides and/or bent bolts that fit the guides to the engine block). Seen this on two vehicles. A sure indicator of this issue would be increased rattling noise coming from the front of the engine at idle, disappearing on slightest push of the accelerator pedal.
Fri May 05 2017 7:30pm |
Hi I don't get the codes on petrol so I know that's just a gas thing and there is no noise on start up when cold or warm it does sound sweet I am going down the electrical route dirat as I said in my previous post it is not consistent so I would have thought if I had valve wear it would be there all of the time which it is not |
Fri May 05 2017 7:37pm |
Yupp, that changes everything. Good luck! Regards etc.,
Fri May 05 2017 8:13pm |
