![]() | Home > Technical > Whining noise after switching off. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Ok. When I switch off I hear a high pitched whining noise for about a minute or so. What is it? Robin
Hi Tim
IIRC they will run on for a short spell to cool enough to prevent the oil frying onto the bearings however it is very good practice with a turbo engine not to come to a halt after a run and just switch off (and it doesn't matter if it is a petrol or diesel) for the longevity of the turbo bearings - the thing gets red hot in operation so some mechanical symphathy is necessary. The whine could also be the cooling fan for the engine running on too, but I know the noise that you mean but while it was very noticable on my previous RRS's and the FFRR's that I have run I never noticed it on either of the Evoques or the L494. Some turbos are water cooled and they make the same noise as the water still has to be circulated to disperse the heat. Not sure if it might not also be the intercooler also circulating cooling water through the system to also dissipate heat. And on some engines it can be the HP fuel pump still running........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I sometimes get that after a sprightly drive, I find it best just to wait it out and the wife quietens the whining down eventually... ![]() 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Brave man to put that in writing |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Yes, never turn off the engine straight away after a hard drive, the spooling is still pumping oil in the turbos to ensure they are cooled and not |
Thanks for all the advice guys. I've uploaded a short video recording the sound and focussed in on where I think its coming from.
The clicking noise in the turbo VVT units opening the closing as a self test or to stop them sticking (and helps with oiling!)
Yes sounds like the shutdown cycle of the EGRs. 07MY RRS TDV6
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1179 ![]() ![]() ![]() |
always allow the turbo to cool down after a drive, especially a spirited one.
Great |
