Home > Technical > rrs suspension fault
bigbaz
England 2007 Range Rover Sport TDV8 HSE Lux Rimini Red
hi people got a problem with my rrs tdv8 .the suspension fault light is on but compressor,relay,and ecu reset have been done and still on my head is done in. Crying or Very sad Crying or Very sad I had it on diagnostics and its come up with ecu fault but where the hell is it.you people ever had this problem before
Post #524998 Mon May 01 2017 6:53pm
geoffsnook
What is the fault code do you have Thumbs Up
Post #524999 Mon May 01 2017 7:01pm
bigbaz
Hi m8 fault codes are u0421 and c1a36
Post #525009 Mon May 01 2017 8:28pm
geoffsnook
C1A36 Exhaust Valve - general electrical failure - intermittent
Sounds as you have an intermittent fault how old is your battery Thumbs Up
Post #525011 Mon May 01 2017 8:34pm
geoffsnook
Have a look here
http://www.rrsport.co.uk/gallery/albums/us...ion%20.pdf
Post #525012 Mon May 01 2017 8:37pm
bigbaz
Hi m8 it's a year old .i know the code points to exhaust valve but it's anew pump and relay it's got me head done in .i read sumwhere that they are prone to the fuse box corroding have you heard this b4
Post #525013 Mon May 01 2017 8:43pm
geoffsnook
Behind the battery has been known to get corroded terminals on the ecu there but also the dryer caps fail on the compressor which i assume you mean was changed a year ago but those parts have been know to go quite quickly Thumbs Up
Post #525014 Mon May 01 2017 8:48pm
bigbaz
Compressor and dryer was done two days ago and I made sure the cap was replaced with aluminium cap befor it was fitted.i didn't know there was ecu terminals behind the battery that's the Nxt thing to try thanks m8 .i will post on here what happens cheers Smile
Post #525016 Mon May 01 2017 8:56pm
bigbaz
Hi all I have checked earth terminals and cleaned them still got the same fault anymore ideas Big Cry
Post #525104 Tue May 02 2017 5:42pm
geoffsnook
Brake light switch rear brake light bulbs are common do a search there also a few connector blocks in the front and rear wheel wells that can give problems do a search on the sister site disco3 as there will be more on there Thumbs Up
Post #525106 Tue May 02 2017 6:07pm
bigbaz
Ok cheers matey Very Happy
Post #525107 Tue May 02 2017 6:49pm
