![]() | Home > Technical > rrs suspension fault |
What is the fault code do you have |
bigbaz Member Since: 01 May 2017 Location: Sherburn in elmet Posts: 7 ![]() ![]() ![]() |
Hi m8 fault codes are u0421 and c1a36 |
C1A36 Exhaust Valve - general electrical failure - intermittent
Have a look here
Hi m8 it's a year old .i know the code points to exhaust valve but it's anew pump and relay it's got me head done in .i read sumwhere that they are prone to the fuse box corroding have you heard this b4 |
Behind the battery has been known to get corroded terminals on the ecu there but also the dryer caps fail on the compressor which i assume you mean was changed a year ago but those parts have been know to go quite quickly |
Compressor and dryer was done two days ago and I made sure the cap was replaced with aluminium cap befor it was fitted.i didn't know there was ecu terminals behind the battery that's the Nxt thing to try thanks m8 .i will post on here what happens cheers |
Hi all I have checked earth terminals and cleaned them still got the same fault anymore ideas |
Brake light switch rear brake light bulbs are common do a search there also a few connector blocks in the front and rear wheel wells that can give problems do a search on the sister site disco3 as there will be more on there |
Ok cheers matey |
