![]() | Home > General > aluminium dustcaps |
paramike Member Since: 02 Mar 2012 Location: scotland Posts: 9 ![]() ![]() ![]() |
hi, if you have tpms, they can oxidise(weld)onto the aluminium dustcap.which i found to my cost |
docian Member Since: 18 Feb 2017 Location: northwest Posts: 19 ![]() ![]() ![]() |
Yep mine welded on, difficult to get off switch to cheap plastic ones, much less hassle |
Always use plastic caps,,we have one customer a week come into our place that can't remove the metal caps cos they have welded themselves on as the valve stem is brass.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I use stainless steel one's, never had any problems also check t/p's on regular basis so proably helps.
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
Electrolytic or galvanic corrosion. Brass to Aluminium is a bad combination. Stainless is OK but plastic is easiest and cheapest.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
just put copper slip on the threads and they will be ok, ive been doing it this way for 10 years 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
