![]() | Home > General > RRS TDV6 - MAF |
Joe-D Member Since: 14 Apr 2017 Location: Scotland Posts: 7 ![]() ![]() ![]() |
Update from this morning
Checked for broken damaged wire MAF sensor, check ECU connections for damage/corrosion. Check for continuity in the wire between the sensor connected and the ECU connecter 2008 G4 RRSport TDV8 current
Thank you for the reply
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
A LR specialist sounds like just what you need, other mechanics are unlikely to have the right equipment to run proper diagnostics.
Hi guys
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
Excellent news. Thanks for updating so others can learn from your experience. I'm in the shed, I'll be back in the real world in a minute. |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
Great news. i was wondering if you'd come back and say it needed a new battery which seems to be a common cause of multiple errors. Merc C220 estate Sport AMG
