Home > Technical > Phone question
potomac
Spain 2006 Range Rover Sport TDV6 HSE Java Black
Phone question
Why when I push the phone key, always the Radio or CD turns on?. I just want to make a call no listen music. I'm using the cradle.
Thanks
Post #51513 Sun Aug 27 2006 7:54pm
Correct. Unfortunately, you cannot currently use the PTI without the radio coming on. Yes, it is annoying....
Post #51603 Mon Aug 28 2006 3:30am
DrLex
Iceland
If it's like the D3 head unit (and I can't think why it wouldn't be), leave it switched on AUX. Car will remember this between 'phone use and car use.
Post #51736 Mon Aug 28 2006 9:12pm
potomac
Yes I've used the AUX function to silence it, but what happen with the amplificator using AUX, will be always on?, could be bad for the AMP, mine has the Premium Sound.
Post #51787 Tue Aug 29 2006 11:12am
PaulB
You also get a quiet but constant "clickerty click" through the speakers if you don't have anything plugged into the AUX socket.
Paul
Post #52039 Wed Aug 30 2006 1:08pm
DrLex
Iceland
Doubt it'd be any worse for it than turning it on and off. After all, my father-in-law keeps his £40K+ hi-fi running 24/7, claiming it runs better this way Rolling Eyes
Paul - if you're getting clicking, why not mention it to the dealer on your next service? Mine is used for ipod interface and I've never noticed clicking when the head unit is on and the ipod is unattached. Perhaps you've an intermittent shorting/grounding problem?
Post #52123 Wed Aug 30 2006 10:27pm
PaulB
I think other people have reported the same clicking. It happens when the head unit is set to AUX and the iPod isn't connected.
It is a continuous rythem, like a very quiet train going over the points Laughing
Paul
Post #52124 Wed Aug 30 2006 10:35pm
DrLex
Iceland
Paul
Had a look for other posts regarding 'AUX', but just found a lot of chat about breasts and Amsterdam Shocked Do you leave the connector plugged in to the AUX socket?
Post #52125 Wed Aug 30 2006 10:52pm
Paul
Laughing Laughing Laughing Pretty much sums it up... Wink
Post #52196 Thu Aug 31 2006 9:58am
DSL
Back on the subject of boobies, it's what this site is good at! Ner Ner
not that I'm complaining, honest!
Post #52206 Thu Aug 31 2006 10:14am
PaulB
Paul
I checked this morning and it only clicks when the cable is left plugged in without the iPod. If I disconnect the cable, the clicking stops. I can only assume the cable is acting as some kind of aerial, but I'm not sure what it is picking up. On a petrol, the obvious conclusion would be the spark plugs, but not on a diesel. Maybe the injectors ?? Confused
Paul
Post #52362 Thu Aug 31 2006 5:54pm
