![]() | Home > Technical > Phone question |
potomac Member Since: 20 May 2006 Location: Barcelona Posts: 3 ![]() ![]() ![]() |
Why when I push the phone key, always the Radio or CD turns on?. I just want to make a call no listen music. I'm using the cradle.
Correct. Unfortunately, you cannot currently use the PTI without the radio coming on. Yes, it is annoying.... |
Yes I've used the AUX function to silence it, but what happen with the amplificator using AUX, will be always on?, could be bad for the AMP, mine has the Premium Sound. |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
You also get a quiet but constant "clickerty click" through the speakers if you don't have anything plugged into the AUX socket.
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
Doubt it'd be any worse for it than turning it on and off. After all, my father-in-law keeps his £40K+ hi-fi running 24/7, claiming it runs better this way ![]() Paul - if you're getting clicking, why not mention it to the dealer on your next service? Mine is used for ipod interface and I've never noticed clicking when the head unit is on and the ipod is unattached. Perhaps you've an intermittent shorting/grounding problem? |
I think other people have reported the same clicking. It happens when the head unit is set to AUX and the iPod isn't connected.
Had a look for other posts regarding 'AUX', but just found a lot of chat about breasts and Amsterdam ![]() |
![]() ![]() ![]() ![]() ![]() 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Back on the subject of boobies, it's what this site is good at! ![]() not that I'm complaining, honest! |
I checked this morning and it only clicks when the cable is left plugged in without the iPod. If I disconnect the cable, the clicking stops. I can only assume the cable is acting as some kind of aerial, but I'm not sure what it is picking up. On a petrol, the obvious conclusion would be the spark plugs, but not on a diesel. Maybe the injectors ?? ![]() Paul |
