Home > Technical > ACC adaptive Cruise Control 2008 HST |
Might be worth looking to see if the radar gun is pointing the right way, it sits behind the box on the front bumper that has ACC written on it. |
Thu Apr 13 2017 9:42am |
Rossco693 Member Since: 13 Feb 2017 Location: Birmingham Posts: 12 |
How easily is it removed? Sorry completely new to RRS'S
Thu Apr 13 2017 10:19am |
I've not looked at it myself so can't give a precise answer, I'm not sure you can remove the cover to view the radar gun without removing the front bumper, it is however easy enough to remove the bumper.
Thu Apr 13 2017 11:52am |
is their an easy way to tell if its pointing in the wrong direction? |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 |
It'll probably be obvious once you remove the cover. I will be very surprised if it's facing the wrong way. Is the cruise control definitely coming on? 2006 Java Black HST Supercharged |
Thu Apr 13 2017 11:58am |
Cruise control works with no issues, comes on stays at speed etc etc. but will not pick up another car infront. going to try on a duel carrage way and a motorway later today to confirm.
Thu Apr 13 2017 12:01pm |
No idea!
Thu Apr 13 2017 12:08pm |
thats the plan,
Thu Apr 13 2017 12:22pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
I would get the car config checked, AFAIK there is no way of disabling the radar and if it was broken I would expect the cruise not to work. I suspect someone may have disabled the radar in the car config because it annoyed them.
Thu Apr 13 2017 3:31pm |
So an update
Thu Apr 13 2017 4:04pm |
As I said previously, check the radar gun. The bracket that holds it isn't very robust so there is every possibility that it slightly too high or too low. It could also be leaves or dirt has built up between the sensor and the cover.
Tue Apr 18 2017 8:10am |
Thanks for that, it's a very good link.
Tue Apr 18 2017 8:23am |
Only a thought - but the ACC and forward alert appears to be speed sensitive. In other words - it will leave a bigger gap between you and the vehicle in front as the speed increases. So if you test it at low speed say with forward alert switched on the alert won't sound until you are "uncomfortably close" to the vehicle in front.
Tue Apr 18 2017 1:12pm |
The problem is it only really picks cars up on the inside lane to me. Not in my lane. Several times putting brakes on while overtaking a lorry.
Tue Apr 18 2017 1:24pm |
