![]() | Home > Maintenance & Modifications > Bolts on rear prop, replace ? |
I re-used the prop bolts |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Yep, should be okay to re-use. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Here's what the workshop manual says:
It does sound as though the flange with the 4 bolts, with a torque setting of 110 lbft may be using stretch bolts. It would be best to replace those, or at least ask if they are stretch bolts. The other end should be fine to re-use. |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
OK, thanks.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Well done. Sounds like a good job.
It was in the local independent some time back for some other work, and he mentioned that the centre bearing was "on the way out". Since then I've had the classic low speed judder when applying power going up hill.
