![]() | Home > Technical > Rear ACE leak repair |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
160 miles with it leaking and I would've thought that the system would run dry. Then you're looking at £1000 for a new pump (that doesn't include fitting).
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I would say it was safe. I drove for quite a while with mine leaking, without any adverse effects whilst I booked a space at my garage. I suggest you get the reservoir topped up but iirc it takes some special fluid, so ensure you use that.
slinger Member Since: 11 Sep 2016 Location: Loughborough, Leicestershire Posts: 19 ![]() ![]() |
Thanks for the replies. Is there any way of pulling a fuse to disable the ACE pump? |
Nope, it's belt driven.
http://www.4x4network.co.uk/location.php Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
I managed to look more closely under the sport this weekend and it looks like it is one of the pies that is leakingk. The ends of the unit look dry but there is a regular drop of fluid dripping of one of the pipes.
It depends which pipe it is. Some require the body to be lifted, others can be changed simply with spanners or pliers. |
Front pipes can be bought individually, but also as a set of 4 Look carefully at the rest of the pipework, I'm sure you will see they are all quite corroded, and risk breaking them while replacing a single pipe... The go from the valve block under the drivers seat, 2x to the front actuator, 1x to the HP pipe from the pump, and the last to the reservoir Dine quite a few sets now. Not particularly difficult, but rather time consuming and fiddly. And the pipes tend to stick into the valve block ![]() |
I wasn't aware you could replace the front pipes individually, I thought they had to be bought as a set under part number: RQA500018
LR019389 - HP pipe - £130 + VAT retail
I hadn't realised that the pipes come away from the bracket that holds all 4 pipes to the valve block... |
