Home > Technical > Rear ACE leak repair
slinger
My 08 RRS HSE has suffered a leak somewhere at the rear. The ACE reservoir is 2/3rds empty and oil dripping from the rear and red malfunction light on. Guess either the ACE rear unit seals have failed or a pipe has let go?
it is safe for me to drive home this week 160 miles?
Anybody know of good independent in Leicestershire area?
Or a good independent in Suffolk where I work?
Post #522196 Tue Mar 28 2017 8:39pm
Socast
160 miles with it leaking and I would've thought that the system would run dry. Then you're looking at £1000 for a new pump (that doesn't include fitting).
I don't know of any garages in your area, so I can't help in that regards. I really wouldn't drive it too far though, certainly with the red warning on the dash.
You might be lucky and it could be one of the oil seals for the feed pipes that attach to the ace bar. That being said the rear bar is the easiest and quickest to replace, so labour shouldn't be to bad if the worst comes to the worst. Rear ace bar is around £800, if you need one buy new, a second hand one may already leak or start leaking not long after fitting. Do it right do it once Thumbs Up
Post #522218 Wed Mar 29 2017 7:50am
Pufftmw
I would say it was safe. I drove for quite a while with mine leaking, without any adverse effects whilst I booked a space at my garage. I suggest you get the reservoir topped up but iirc it takes some special fluid, so ensure you use that.
When you come to get a new one, go on eBay and you can get the same make as the OE rear ACE, just not LR branded, for about £785 inc VAT/del. Reasonable discount on the £1200+VAT from a dealer.
Post #522220 Wed Mar 29 2017 7:55am
slinger
Thanks for the replies. Is there any way of pulling a fuse to disable the ACE pump?
Post #522232 Wed Mar 29 2017 10:19am
Socast
Nope, it's belt driven.
If you really must drive, make sure the reservoir is topped up (stop every couple of miles or so, you'll soon know how far you can go based on fluid loss) and try to take corners as gently as possible so as to avoid the ace system trying to prevent body roll.
Post #522233 Wed Mar 29 2017 10:31am
DrRob
Re: Rear ACE leak repair
http://www.4x4network.co.uk/location.php Visitor from fullfatrr.com
Post #522236 Wed Mar 29 2017 11:06am
slinger
I managed to look more closely under the sport this weekend and it looks like it is one of the pies that is leakingk. The ends of the unit look dry but there is a regular drop of fluid dripping of one of the pipes.
Any information on where the pipes go to and how hard to change, part numbers etc. Any help would be most appreciated.
Post #522650 Sun Apr 02 2017 7:16pm
Socast
It depends which pipe it is. Some require the body to be lifted, others can be changed simply with spanners or pliers.
Post #522651 Sun Apr 02 2017 7:20pm
Disco_Mikey
Front pipes can be bought individually, but also as a set of 4
Look carefully at the rest of the pipework, I'm sure you will see they are all quite corroded, and risk breaking them while replacing a single pipe...
The go from the valve block under the drivers seat, 2x to the front actuator, 1x to the HP pipe from the pump, and the last to the reservoir
Dine quite a few sets now. Not particularly difficult, but rather time consuming and fiddly. And the pipes tend to stick into the valve block Big Cry
Post #522693 Mon Apr 03 2017 6:08am
Socast
I wasn't aware you could replace the front pipes individually, I thought they had to be bought as a set under part number: RQA500018
If you could provide the part numbers for the return and high pressure pipe that would be great. Bow down
Post #522704 Mon Apr 03 2017 8:14am
Disco_Mikey
LR019389 - HP pipe - £130 + VAT retail
LR019388 - to actuator "B" - £184
LR019387 - to actuator "A" - £184
LR020003 - to reservoir - £136
RQA500018 - pipe set - £258 + VAT
Cheaper to buy the whole lot, as well as being much quicker and easier to fit Wink
Post #522748 Mon Apr 03 2017 1:48pm
Socast
I hadn't realised that the pipes come away from the bracket that holds all 4 pipes to the valve block... Embarassed
Post #522756 Mon Apr 03 2017 2:03pm
