Home > Wheels & Tyres > Locking wheel nuts
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Locking wheel nuts
Guys, my new RRS has some Cades Statutum Tempus MMV alloys but no locking wheel nuts. I want to buy some but don't know if standard ones will fit or do I need ones for after market alloys ?
Thanks
[img]http://www.rrsport.co.uk/gallery/albums/userpics/17641/normal_IMG_5424~1.PNG[/img]
Post #521962 Sun Mar 26 2017 7:10pm
Neils RRS
Scotland
The locking wheel nuts on many LR vehicles have a really bad design flaw in them. They can and do part halfway at the stainless cap and makes it a nightmare to get them off. I just spent about 8 hours trying to get one off and now have to get my wheels refurbed. I have bought standard nuts to replace them. If you want them, make sure you either free them off periodically, ensure no one ever uses anything other than their hands to loosen or tighten them, or go non oem.
Do a search, it's all over the web, P38 RR, RRS, Disco, they must have used them for years knowing they were flawed.
Post #522483 Fri Mar 31 2017 9:32pm
Odd one that, I have had Range Rovers for the last 25 odd years and have not once had a wheel nut problem but then I have always used the correct size socket and a torque wrench as well as a small amount of copperslip on the threads.
Post #522498 Fri Mar 31 2017 11:25pm
sestorious
Thanks for the info guys ! So do these after market wheel need different lockers or will standard one fit please ?
Post #522501 Sat Apr 01 2017 6:19am
syl
Just put non-locking nuts on. I had a similar designed jaguar nut get stuck - rather than try to chisel it, find someone with a dynomec kit and give them £20.
Post #522541 Sat Apr 01 2017 2:25pm
Oldandconfused
Bit of a thread resurrection here, but was at may local indi re a steering wheel alignment issue, took the opportunity to have mine changed for normal nuts. Looks better and no danger of the "key" disintegrating at the side of the road.
FYI, Ian (Fenland 4x4 Thumbs Up ) cured the steering wheel issue by swapping the Crapinentals from the front to the rear-wheel centered, had a chat and nuts swapped (in a good way Embarassed ).
Post #534738 Thu Sep 07 2017 4:31pm
