Home > Wheels & Tyres > Locking wheel nuts |
Neils RRS Member Since: 14 Oct 2014 Location: Aberdeen Posts: 47 |
The locking wheel nuts on many LR vehicles have a really bad design flaw in them. They can and do part halfway at the stainless cap and makes it a nightmare to get them off. I just spent about 8 hours trying to get one off and now have to get my wheels refurbed. I have bought standard nuts to replace them. If you want them, make sure you either free them off periodically, ensure no one ever uses anything other than their hands to loosen or tighten them, or go non oem.
Fri Mar 31 2017 9:32pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Odd one that, I have had Range Rovers for the last 25 odd years and have not once had a wheel nut problem but then I have always used the correct size socket and a torque wrench as well as a small amount of copperslip on the threads.
Fri Mar 31 2017 11:25pm |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 |
Thanks for the info guys ! So do these after market wheel need different lockers or will standard one fit please ? |
Sat Apr 01 2017 6:19am |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 |
Just put non-locking nuts on. I had a similar designed jaguar nut get stuck - rather than try to chisel it, find someone with a dynomec kit and give them £20. |
Sat Apr 01 2017 2:25pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Bit of a thread resurrection here, but was at may local indi re a steering wheel alignment issue, took the opportunity to have mine changed for normal nuts. Looks better and no danger of the "key" disintegrating at the side of the road.
Thu Sep 07 2017 4:31pm |
