![]() | Home > General > Parking sensor flashing light |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
Sorry I think I have posted in the wrong section, I cant delete it so if the mods want to move it to the right section thats ok. |
Probably not the fuse.
the rear speaker does need changing its gone really low, I can hardly hear it. Will check around the fuse box tomorrow, just a lot of wiring its like looking for a needle in a haystack. Is there anywhere I can download an electrical diagram? |
the speaker changes tone to give an error tone.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
If you have a continuous tone and the flashing light it could be water in the sensors. Have you just washed it perhaps with a sprayer or driven in heavy rain? If so let them dry out and it may fix itself. Not a permanent solution but it might help determine where the fault is. Robin
Hi
Bizzar.
Strange all day yesterday it was flashing. No beeps apart from the rear sensors working as they should (beeper is low though), fronts not working at all. Today just been a run round to the shops, its been chucking it down with rain all night and they have worked perfectly. Strange beasts these cars are. |
Haha. Shows how much I know😊 Robin
Damn its been dry all morning and they have faulted again. put the hawk eye on it but there isn't a section to read the PDC. |
Aha. So the way forward; if you're going out somewhere and might want to park, make sure its raining. Problem solved! |
Sorry, that wasn't very constructive but I'm at a loss now... |
the only thing I have done is have the panels out under the glove box, by the fuse box. maybe I have disturbed something. I am waiting for a piggy back fuse to come so I can fit my dash cam, while I am fitting that I will check all the plugs under there, just in case.
Sorry to follo w up again (you'll be getting fed up with me) but these may be useful:
