Home > Maintenance & Modifications > RRS 4.2 v8 supercharged 2008 maintenance |
The gearbox is the same as any other rrs, oil needs changing at 100k miles or 10 years, as for the engine, the spark plugs last for 100k miles so you don't need to worry about those. Use high quality oil (I use Fuchs Titan Race Pro), if you don't it'll end up needing new timing chains (I was told by a LR dealership that its a 20 or 30 hour job) the kit alone is nearly £500.
Tue Mar 28 2017 7:09pm |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 |
Many thanks for your reply ! Love the V8 sound and so do the public when I pass them !
Tue Mar 28 2017 7:25pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello. There is a tsb explaining the supercharger coolant pump wiring, but generally the only way you find out, if you are driving hard in hot weather. An error comes up saying reduced power. Pull up and turn ignition off and back on clears it. I found mine was incorrectly wired doing 80 up the steep hills into Monaco, so it probably will not affect most cars in the UK. I had my sc for seven years and it was only while in the south of France that it ever played up. On the upside the coolant pump is only around £120 and you just shave a lug off to enable the connector to be reversed. MY12 RRS HSE
Tue Mar 28 2017 7:56pm |
Just found my old write up
Tue Mar 28 2017 7:59pm |
