Home > General > Jacking up |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4947 |
passenger side can be a pain with the trolley jack as there is the suspension tank at the front and compressor cover at the back to avoid. |
Thu Mar 23 2017 12:09pm |
Bulletsaints Member Since: 26 Feb 2017 Location: Southampton Posts: 59 |
It's n/s front I've got to Jack up as well lol poping to my mates garage later so not sure if he will you a ramp or not, got a caliper sticking and I'm hoping it's just the sliders or I'll need to order a new caliper.
Thu Mar 23 2017 12:14pm |
Jack up under bottom arm,,ive never raised vehicle to jack up & ive done hundreds & never had a problem,,,you can lift the suspension to make it easier but make sure you have a good trolley jack & put a axle stand under vehicle.
Thu Mar 23 2017 12:24pm |
Thu Mar 23 2017 12:34pm |
I bought a bottle jack just for the sport, I found that unless you want to spend big bucks the jack won't lift high enough without blocks etc. |
Thu Mar 23 2017 2:05pm |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 |
raise the suspension to highest mode as per the handbook then I use my 3 tonne trolly jack. No issues so far. Just had a sticky rear calliper issue as well the pistons weren't moving on passenger rear and driver rear had a sticky pad resulting in complete set of callipers, discs and pads. My main issue the discs and pads were only 10K old so I think the issue was masked by Knutsford Range Rover before I took delivery |
Thu Mar 23 2017 4:13pm |
Yer think I'll need new caliper and disk and pads, n/s front disks is getting very hot after a good few miles, only noticed when I was rinsing car of and water touched the disc. And very slightly pulls to the right when braking so obviously doing more work than the n/s didn't want to order new straight away as was told could be sticking in sliders ? |
Thu Mar 23 2017 4:19pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
apologies for going off at a tangent, but are regular tyre fitters such as kwikfit, Formula 1 etc OK to use to change tyres, tracking, etc? Merc C220 estate Sport AMG
Thu Mar 23 2017 4:30pm |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
I just jack the whole thing up at the front
Thu Mar 23 2017 4:51pm |
No not brembos mate, and the pads have got loads on them really so not to sure about that. I'm having someone look at it as my days of playing with motors are over lol I used to love doing my own bits but no longer have the tools etc to do it anymore. |
Thu Mar 23 2017 5:00pm |
say if new discs,calipers and pads will be required in your case just saying what I ended up needing. I am hoping the Guy Salmon can come through with some reimbursement on the total bill as I went in with it today to talk to the service manager who is now investigating. I have also said I would like the rear ACE replacing under warranty as it has a leak and came as an advisory on my MOT |
Thu Mar 23 2017 8:49pm |
Bump. Just interested in whether the regular tyre and alignment people can be used for RRS work or should i use a more specialist outfit? Do they all know the where the correct jacking points are, etc? Merc C220 estate Sport AMG Merc C220 estate Sport AMG 125 year edition Alfa GT Rover 76 V6 |
Wed Mar 29 2017 11:42am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Hunters kit and someone who knows the cars....
Wed Mar 29 2017 3:36pm |
