Home > General > Jacking up
Bulletsaints
England 2005 Range Rover Sport TDV6 SE Java Black
Jacking up
Hi all......is there anything in particular that you've got to do when Jacking the rrs up ? Jacking one corner!! And is it any different when using a garage ramp, or 4 post lift. Thanks in advance
Post #521730 Thu Mar 23 2017 12:02pm
passenger side can be a pain with the trolley jack as there is the suspension tank at the front and compressor cover at the back to avoid.
Post #521732 Thu Mar 23 2017 12:09pm
Bulletsaints
It's n/s front I've got to Jack up as well lol poping to my mates garage later so not sure if he will you a ramp or not, got a caliper sticking and I'm hoping it's just the sliders or I'll need to order a new caliper.
Just I'm sure someone said something about when Jacking to leave boot open ? And put it in highest suspension setting ?
Post #521733 Thu Mar 23 2017 12:14pm
Tyrefitter
Jack up under bottom arm,,ive never raised vehicle to jack up & ive done hundreds & never had a problem,,,you can lift the suspension to make it easier but make sure you have a good trolley jack & put a axle stand under vehicle.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #521734 Thu Mar 23 2017 12:24pm
Bulletsaints
Post #521735 Thu Mar 23 2017 12:34pm
Socast
I bought a bottle jack just for the sport, I found that unless you want to spend big bucks the jack won't lift high enough without blocks etc.
Post #521739 Thu Mar 23 2017 2:05pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
I Always
raise the suspension to highest mode as per the handbook then I use my 3 tonne trolly jack. No issues so far. Just had a sticky rear calliper issue as well the pistons weren't moving on passenger rear and driver rear had a sticky pad resulting in complete set of callipers, discs and pads. My main issue the discs and pads were only 10K old so I think the issue was masked by Knutsford Range Rover before I took delivery
Post #521750 Thu Mar 23 2017 4:13pm
Bulletsaints
Yer think I'll need new caliper and disk and pads, n/s front disks is getting very hot after a good few miles, only noticed when I was rinsing car of and water touched the disc. And very slightly pulls to the right when braking so obviously doing more work than the n/s didn't want to order new straight away as was told could be sticking in sliders ?
Post #521751 Thu Mar 23 2017 4:19pm
Bill Portland
apologies for going off at a tangent, but are regular tyre fitters such as kwikfit, Formula 1 etc OK to use to change tyres, tracking, etc? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #521752 Thu Mar 23 2017 4:30pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
I just jack the whole thing up at the front Rolling Eyes
on the calliper, if pads are low sometimes the pistons can stick a bit since they are long way out, it also helps to push the pistons fully back while theyre off to free them, but remember to watch fluid level and pump pedal after to push them back out. (sorry if im teaching how to...eggs) Smile , but ive had issues before with the m3 callipers having similar issues.
also, has yours got brembos mate?, aren't they a fixed calliper with 4 pistons?
Post #521754 Thu Mar 23 2017 4:51pm
Bulletsaints
No not brembos mate, and the pads have got loads on them really so not to sure about that. I'm having someone look at it as my days of playing with motors are over lol I used to love doing my own bits but no longer have the tools etc to do it anymore.
Post #521757 Thu Mar 23 2017 5:00pm
scousefly
Cant
say if new discs,calipers and pads will be required in your case just saying what I ended up needing. I am hoping the Guy Salmon can come through with some reimbursement on the total bill as I went in with it today to talk to the service manager who is now investigating. I have also said I would like the rear ACE replacing under warranty as it has a leak and came as an advisory on my MOT
Post #521770 Thu Mar 23 2017 8:49pm
Bill Portland
Bump.
Just interested in whether the regular tyre and alignment people can be used for RRS work or should i use a more specialist outfit? Do they all know the where the correct jacking points are, etc? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #522240 Wed Mar 29 2017 11:42am
DrRob
Hunters kit and someone who knows the cars....
www.alignmycar.co.uk Visitor from fullfatrr.com
Post #522250 Wed Mar 29 2017 3:36pm
