Home > Faults & Fixes > Rrs red suspension light on help !
jvautos
when i took it to range rover be for they said
FAULT WITH ARC SYSTEM CHECKED FLUID AND WAS LOW TOPED UP ARC FLUID
REMOVED ARC FILTER AND FOUND METAL PARTICLES CLEANED THE FILTER
AND REFITTED BLEAD SYSTEM AS AIR SUSPECTED IN SYSTEM . CLEARED FAULTS OUT OF THE SYSTEM
AND ROAD TEST
ANY IDEAS ? ANY ONE WHAT IT COULD BE
Post #371711 Thu Jan 31 2013 10:30am
Bodsy
Site Sponsor
Seriously JV, I lknow you're just set up and all, but you really should get an SDD licence which would do a lot of the diagnostics on the issue for you. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371716 Thu Jan 31 2013 11:21am
jvautos
replaced arc pump seems ok at the moment but now the stereo and sat nav screen has paked up
Post #371802 Thu Jan 31 2013 10:13pm
ramiro_norte
Argentina 2007 Range Rover Sport TDV8 HSE Bonatti Grey
Re: Rrs red suspension light on help !
HI, I have the same code error. U0434. How did you resolved the problem?
Post #423793 Fri May 09 2014 5:58pm
Edmundz1
Any luck on resolving this fault?
Post #521368 Sun Mar 19 2017 6:56pm
