Home > General > new guy here (need help)
Ratman
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
hi guys
can any of you guys help ,I just had new tyres fitted on rear of my rrs 2008 2.7 20in
when I do around 40 to 60 mph on a bend or going around a roundabout, I loose traction on one wheel light flashes amber
car slows down, little gridding noise ,and then drives fine
can any one sheds some ideas on this
many thanks Thumbs Up
Post #521230 Fri Mar 17 2017 11:11pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Maybe the Tyre fitters have dislodged/moved one of the wheel sensors which is playing havoc with the systems. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #521238 Sat Mar 18 2017 1:01am
The symptoms point to the traction control / DSC kicking in which suggests a wheel speed error. Could be a steering wheel calibration but as the wheels have been removed and replaced, suspect the wheel speed sensors. An error code check would be useful too. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #521240 Sat Mar 18 2017 1:13am
Ratman
Thanks guys, are there speed sensor on both rear wheels
tyres pressure is on 40psi is this ok
Post #521241 Sat Mar 18 2017 6:51am
Hocks172
Also there was a post the other day about the differing size of tyres, even thou the tyres might say the right size the different manufacturers have different sizes thus throwing the system into a fit.
Are they the same branded tyre? RRS Autobiography SDV6 19
Tesla model 3 long range SOLD!
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #521242 Sat Mar 18 2017 7:10am
Camelrock
33 fronts and 36 rear. As well as the above might be worth getting the rear sus bushes checked out as you can get this fault when there is a lot of play in the inner upper bush. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #521243 Sat Mar 18 2017 7:14am
Bodsy
Site Sponsor
Wheel alignment
Worn bushes
Steering wheel calibration
Tyre pressures
Height calibration
Can all cause the symptoms you're getting. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #521247 Sat Mar 18 2017 8:33am
check the tyres sizes match front to rear.
If the others are very worn it's probably worth getting them changed too before wasting money on other things
Post #521273 Sat Mar 18 2017 10:22am
shepp
Definitely worth getting the wheel alignment checked. On my last RRS the traction control would kick in on roundabouts and twisty roads. Was exaggerated when I had new tyres. Alignment fixed the issue and massively improved the handling. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #521286 Sat Mar 18 2017 11:53am
Ratman
nice 1 guys,
both tyres are the same size and branded ,and the fronts are the same size but different branded to the rear
took it up to 80 nice and smooth ,had it on ramp ,rear bushes look ok
don't no how to check, for height calibration,
will lower the pressure to 36 to see any change
next stop will be Alignment
hopefully with your help I will get it sorted
Post #521296 Sat Mar 18 2017 1:54pm
SRE
Spain
This one Question
http://www.rrsport.co.uk/forum/topic35871.html In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #521302 Sat Mar 18 2017 2:32pm
Hocks172
Thumbs Up RRS Autobiography SDV6 19
RRS HST Sold!
Post #521330 Sat Mar 18 2017 11:03pm
Ratman
Thanks for your advise ,had the Alignment done today ,what a massively improvement ,no more flashing light
Post #521697 Wed Mar 22 2017 7:33pm
