Home > General > new guy here (need help) |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Maybe the Tyre fitters have dislodged/moved one of the wheel sensors which is playing havoc with the systems. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Sat Mar 18 2017 1:01am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
The symptoms point to the traction control / DSC kicking in which suggests a wheel speed error. Could be a steering wheel calibration but as the wheels have been removed and replaced, suspect the wheel speed sensors. An error code check would be useful too. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 18 2017 1:13am |
Ratman Member Since: 16 Mar 2017 Location: bristol Posts: 14 |
Thanks guys, are there speed sensor on both rear wheels
Sat Mar 18 2017 6:51am |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 |
Also there was a post the other day about the differing size of tyres, even thou the tyres might say the right size the different manufacturers have different sizes thus throwing the system into a fit.
Sat Mar 18 2017 7:10am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
33 fronts and 36 rear. As well as the above might be worth getting the rear sus bushes checked out as you can get this fault when there is a lot of play in the inner upper bush. 2008 G4 RRSport TDV8 current
Sat Mar 18 2017 7:14am |
Wheel alignment
Sat Mar 18 2017 8:33am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
check the tyres sizes match front to rear.
Sat Mar 18 2017 10:22am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Definitely worth getting the wheel alignment checked. On my last RRS the traction control would kick in on roundabouts and twisty roads. Was exaggerated when I had new tyres. Alignment fixed the issue and massively improved the handling. MY12 RRS HSE
Sat Mar 18 2017 11:53am |
nice 1 guys,
Sat Mar 18 2017 1:54pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
This one http://www.rrsport.co.uk/forum/topic35871.html In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Sat Mar 18 2017 2:32pm |
RRS Autobiography SDV6 19
Sat Mar 18 2017 11:03pm |
Thanks for your advise ,had the Alignment done today ,what a massively improvement ,no more flashing light |
Wed Mar 22 2017 7:33pm |
