![]() | Home > Technical > Noisey ACE Pump |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
Thought I had better post under this section you socast
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I've changed everything bar the roll bars themselves, but it's physically impossible for it to be them. The only possibility I have left is part: RQA500018 this is the bunch of pipes that leads to the front sway bar, reservoir and pump. But at £300 and a partial body lift to replace them I'm somewhat hesitant to pull the trigger. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Are you absolutely sure it's not the alternator? I had a very similiar thought about the ACE pump being noisy and firstly suspected the reservoir was starving the pump with a blocked internal filter so I changed that, plus I changed the high pressure filter in the valve block at the same time. Of course, the noisy high pitch whine remained so the next thing was plan to change the pump.
I'm certain it's not the alternator as I've replaced it already, along with all idlers that are near-by. The confirmation was when I used remote microphones, the pump is noisier on the inlet than it is on the outlet oddly enough. |
Does the ACE fluid look aerated in the reservoir after a good long drive? Even the slightest of leak anywhere in the pipe between the reservoir and the pump, will be enough for the pump to pull in air and make it sound bad. |
Nope, fluid is fine. Following my opening post Other than the sway bars it's a completely new system, pipes, valve block, reservoir and pump.
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
was alternator changed as a result of hearing this noise? and recently?. as GodivaNige says I would suspect alternator. mine had exact same symptoms before failing completely |
I've had remote microphones on the pump it is 100% the pump. I replaced the alternator 2 months ago. When I changed the ace pump I filled the reservoir and started the engine, no whine, the second the oil reached the pump, it started to whine. |
If the noise is definitely coming from the pump, then it's either another faulty pump OR there is something restricting flow from the pump causing it to work beyond its design limit OR it is cavitating due to a restriction of fluid feed from the reservoir.
There than the ace bars and part number rqa500014 I have replaced the ENTIRE system with brand new components. Everything is as it should be, the system passes all tests and throws no errors/fault codes. Land rover have said the pump is fine and that's how it's supposed to sound... |
My ace pump is brand new too, I will have another listen to the pump tomorrow as I haven't had time since Wednesday then I got the RR back.
My noise is defo still coming from the ACE pump, it still sounds the same before I have the new pump fitted !!!
When you changed the pump and fluid, I'd you fit a new reservoir? |
Yep 2 new filters, new fluid, new pump all fitted by www.west4x4co.uk 2006 RR Sport Supercharged Love this car
