Home > Technical > Noisey ACE Pump
Socast
Noisey ACE Pump
Hi Everyone,
I'm having a bit of a nightmare trying to resolve a noisy ACE pump.
Whilst I've always known/thought it was the pump I replaced the cheaper bits before shelling out £1k on a new pump. So with this in mind I've replaced the two idler pulleys that are located close to the pump (to rule out any noise transference and also at 10 years old they benefited from being changed), I've replaced the reservoir (to rule out the micro filter in there) , I've replaced the main valve block (to eliminate the possibility that the solenoids aren't working correctly and also I saw a cheap new one) and lastly I've changed the actual pump. The system was bled and flushed using the usual process and passed each of the three times it was ran. However it's still screaming like a banshee when it hits 1500rpm and above.
I'm kind of at a loss as to what else it could be, the stethoscope pinpointed the pump. The Land Rover warranty means they want diagnose the fault before swapping the pump, I'm just a little worried that the dealership will try to explain the fault away and blame some other component whist fleecing me in the process (I'm already into this repair for £1600+ so not really keen on spending anymore Big Cry ).
Any ideas on what else it can be ?
Post #496501 Thu May 19 2016 10:26am
delta351
Ace pump
Thought I had better post under this section you socast
I am having the same problem also and I have changed pump, flitters & fluid
Ive spent £1350 so far Big Cry 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521119 Thu Mar 16 2017 8:09pm
Socast
I've changed everything bar the roll bars themselves, but it's physically impossible for it to be them. The only possibility I have left is part: RQA500018 this is the bunch of pipes that leads to the front sway bar, reservoir and pump. But at £300 and a partial body lift to replace them I'm somewhat hesitant to pull the trigger.
Post #521120 Thu Mar 16 2017 8:58pm
GodivaNige
Are you absolutely sure it's not the alternator? I had a very similiar thought about the ACE pump being noisy and firstly suspected the reservoir was starving the pump with a blocked internal filter so I changed that, plus I changed the high pressure filter in the valve block at the same time. Of course, the noisy high pitch whine remained so the next thing was plan to change the pump.
However, before I got around to changing the pump, the alternator gave up, lots of weird electrical behaviour followed immediately by the red battery on the dash.
I had the alternator replaced and no more noise. Not once did I suspect the alternator, I've never heard one make a noise like this, when I've had failed alternators on other vehicles in the past they've always made a more low pitch grating noise, not a high pitch whine.
I know you've checked with a stethoscope so you're more likely to be confident about what you think is at fault, just saying don't discount the alternator, it had me fooled Embarassed Confused Thumbs Up
Post #521123 Thu Mar 16 2017 9:24pm
Socast
I'm certain it's not the alternator as I've replaced it already, along with all idlers that are near-by. The confirmation was when I used remote microphones, the pump is noisier on the inlet than it is on the outlet oddly enough.
Post #521125 Thu Mar 16 2017 9:30pm
GodivaNige
Does the ACE fluid look aerated in the reservoir after a good long drive? Even the slightest of leak anywhere in the pipe between the reservoir and the pump, will be enough for the pump to pull in air and make it sound bad.
Post #521127 Thu Mar 16 2017 9:43pm
Socast
Nope, fluid is fine. Following my opening post Other than the sway bars it's a completely new system, pipes, valve block, reservoir and pump.
The pump before it was bled up was silent, the second the oil from the reservoir reached the pump it started to whine.
Post #521128 Thu Mar 16 2017 9:47pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
was alternator changed as a result of hearing this noise? and recently?. as GodivaNige says I would suspect alternator. mine had exact same symptoms before failing completely
Post #521178 Fri Mar 17 2017 1:09pm
Socast
I've had remote microphones on the pump it is 100% the pump. I replaced the alternator 2 months ago. When I changed the ace pump I filled the reservoir and started the engine, no whine, the second the oil reached the pump, it started to whine.
Post #521179 Fri Mar 17 2017 1:13pm
GodivaNige
If the noise is definitely coming from the pump, then it's either another faulty pump OR there is something restricting flow from the pump causing it to work beyond its design limit OR it is cavitating due to a restriction of fluid feed from the reservoir.
As you have changed the reservoir, you can rule out a blocked microfilter (within the reservoir), have you checked the pipe between the reservoir and the pump for kinks or anything pinching it?
If this pipe looks ok, then you'll need to investigate a restriction between the pump and the valve block. As there is a pressure transducer on the valve block, any restriction from the valve block to the ARB's would like throw a fault up on the dash.
Post #521183 Fri Mar 17 2017 2:07pm
Socast
There than the ace bars and part number rqa500014 I have replaced the ENTIRE system with brand new components. Everything is as it should be, the system passes all tests and throws no errors/fault codes. Land rover have said the pump is fine and that's how it's supposed to sound... Rolling Eyes
Post #521184 Fri Mar 17 2017 2:11pm
delta351
Ace Pump
My ace pump is brand new too, I will have another listen to the pump tomorrow as I haven't had time since Wednesday then I got the RR back.
I will also see if I can get to the alternator too. 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521202 Fri Mar 17 2017 7:09pm
delta351
My noise is defo still coming from the ACE pump, it still sounds the same before I have the new pump fitted !!!
and the noise sounds awful my wife took the dogs out in the RR yesterday and when she pulled away all I could hear
was the Censored ACE pump !!!!!! Big Cry 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #522601 Sun Apr 02 2017 7:22am
GodivaNige
When you changed the pump and fluid, I'd you fit a new reservoir?
Post #522604 Sun Apr 02 2017 8:10am
delta351
Yep 2 new filters, new fluid, new pump all fitted by www.west4x4co.uk 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #522606 Sun Apr 02 2017 8:15am
