Home > General > Another problem just raised its ugly head!! |
danboy Member Since: 20 Dec 2016 Location: st neots Posts: 27 |
Hi Guys
Mon Mar 06 2017 9:04pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Is it the complete tail gate, or just the top hatch?
Mon Mar 06 2017 9:52pm |
hi,
Mon Mar 06 2017 10:11pm |
at the moment its the whole tailgate 2007 RRS HSE |
Mon Mar 06 2017 10:18pm |
Well, that's my theory of tailgate switch malfunction.
Mon Mar 06 2017 10:21pm |
cheers dan, ill have a look tomorrow.
Mon Mar 06 2017 10:32pm |
The switch from the upper tailgate is 5 minutes to get out, but you need the top hatch open. 2 ways, 1 you can either use a flat blade small screw driver and push it in and prise it out(there is spring tabs either side) but these can break. Or look underneath on the inside there's 8 t20 screws that you remove then the trim on the outside can be slid up and off, exposing the rear window beam and switch, from there it's a simple push out. |
Mon Mar 06 2017 10:36pm |
ok ill give it a go, whats troubling me though is that its the whole tailgate not just the top window. ill have a look anyway.
Mon Mar 06 2017 10:39pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5002 |
Do you have a sunroof. |
Tue Mar 07 2017 5:14am |
Hi Andy. No mate. No sunroof. Went out this morning and sure enough the tailgate
Tue Mar 07 2017 7:35am |
Try doing a soft reset of the car (disconnect the battery leads and then touch them together, this purges all residual power in all the systems).
Tue Mar 07 2017 12:16pm |
