Home > General > Vibration question |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Have you checked the bushes are worn? Visitor from fullfatrr.com
Sun Feb 26 2017 6:37pm |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 138 |
Hi , what would be the best way of checking this Dr rob , generally speaking the car seems to drive fine on most roads but you notice a solid thump when going over rough road surfaces which I had put down to sports suspension being firm , but since driving the disco 4 the ride quality is so much better in the discovery , steering seems more refined as well |
Sun Feb 26 2017 6:54pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
This could well be a bushes issue but if you have larger wheels and low profile tyres compared to the disco then this will give you a harsher ride over the crap potholed roads we see these days.
Sun Feb 26 2017 7:08pm |
Wheels on my tdv8 are standard 20 inch rims running on 275/45/20 I opted to putting 45 profile to help with ride which definately improved things last summer , I have checked both front wheel bearings by jacking up each corner and checking for any play and found nothing , I suspect wishbone bushing being the culprits as my car has covered 95000 miles and I have no history of either being replaced at any stage |
Sun Feb 26 2017 7:48pm |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
I changed the front arms on mine last time i had the body off, it was like driving a different car! spiteful Range Rover Sport tdv8 |
Sun Feb 26 2017 8:21pm |
Perhaps take it to an independent LR specialist for their assessment?
Sun Feb 26 2017 8:22pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 937 |
As olly said, I changed the front lower arms on mine and also did wheel bearings the same time as I could hear a rumble when going round right hand bends. It was like Frizington a new car when they had been done. If yours is on 95k they must be ready for replacement by now.
Mon Feb 27 2017 4:41am |
Don't know where Frizington came from!!!!! Should be driving 2010 RRS, TDV8
Mon Feb 27 2017 4:42am |
