Home > Faults & Fixes > ABS warning lights all on
Suthy
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Santorini Black
Hi all
I have a 2011 RRS HSE Autobiograhpy, 84000 miles and have been getting loads of yellow warnings up on the dash, ABS, hand brake etc. it happened one morning when I went to start the car,
I have just read the DTC's and have found the rear left speed sensor not sensing speeds when driving, I know its easy to replace the sensor but would like to trace the wiring just to make sure there are no breaks, this is where I need the help
where can I find where the cabling goes from the plug next to the wheel???
And would this problem bring up all the warnings??
Post #518214 Sun Feb 19 2017 11:49am
Suthy
Ok, I have now replaced the rear left speed sensor as this wasn't showing any speed when moving whilst my reader was connected, This made no difference.
Fault codes that wont reset are:
U0415-Invalid data from ABS control module
U0416-Invalid data from vehicle dynamic control module
U043A-Invalid data from suspension control module
Can anybody help. I'm sure its something to do with the rear left sensor,
I have removed the brake lever switch, this all seems to work fine.
No bulbs have blown, all fuses ok
Post #518516 Tue Feb 21 2017 7:21pm
Suthy
Ok, after getting the workshop manuals from Naks, I have traced the wiring looms, tested for continuity between the wiring sensor connector C0502 and the front connector C2294T, and have found a break in the white cable, as there are no connectors in between these points I will have to run another cable to replace the broken one, I will run a temporary one first just to double check my findings.
Post #519066 Sun Feb 26 2017 5:50pm
Suthy
All sorted, ran a new cable in between the 2 connectors and wired up, all yellow warning lights are now off.
Success
Post #519235 Mon Feb 27 2017 10:29pm
Eaters
Well done for your perseverance. Thumbs Up thanks for posting. It's all useful info for others Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #519238 Mon Feb 27 2017 10:53pm
