Home > General > Passenger front window help?
Tizzard
Hi all. Was driving on Sunday when me wife said she could hear wind like a window was slightly down on her side of the car but her window was up. When we got home I looked to find that when you put the window up it don't go right to the top at the back of the window by 2,3mm put you can slide it up by hand Shocked I'm not sure how long it's been like this for is there any adjustment on the runner or any ideas what could be the problem? The window goes up and down fine but not going right to the very top at the back part.
Cheers wayne
Post #518341 Mon Feb 20 2017 11:46am
Paddi
Have you tried closing the window and holding the switch in the 'close' position for one second? Should recalibrate. 2008 MY Java Black TDV8 HSE
Post #518348 Mon Feb 20 2017 12:17pm
Tizzard
No I haven't. I will give it ago when I get home from work. Does it matter if I use the switch on the passenger side or the switch on the drivers side?
Post #518353 Mon Feb 20 2017 12:49pm
Socast
What year is your car ?
Post #518367 Mon Feb 20 2017 2:37pm
Tizzard
It's a 2007 tdv8 Thumbs Up
Post #518377 Mon Feb 20 2017 3:52pm
Socast
As has already been said, to recalibrate the window position, close the window and keep the switch pressed for one second.
You may also want to check for any debris in the window traps.
There is an anti-trap mechanism (front windows only)
If the anti-trap sensor detects an obstruction during window closing, the window will stop and then open slightly.
The anti-trap feature can be overridden by attempting to close the window at intervals of less than 10 seconds, on the fourth attempt the window will move up a short distance with increased force to try and move the obstruction.
If this fails to move the obstruction, anti-trap will be disabled until reset.
To reset anti-trap, close the window and keep the switch pressed for one second
Post #518381 Mon Feb 20 2017 4:22pm
Tizzard
Thanks all. Just got home put the window down then up as far as it would go then held the up button down for 2 seconds then the window went up then little bit more and closed Thumbs Up
Post #518386 Mon Feb 20 2017 4:52pm
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Here is an alternative solution! http://www.rrsport.co.uk/forum/topic46827.html
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #518389 Mon Feb 20 2017 5:53pm
