![]() | Home > General > Passenger front window help? |
Have you tried closing the window and holding the switch in the 'close' position for one second? Should recalibrate. 2008 MY Java Black TDV8 HSE
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 ![]() ![]() |
No I haven't. I will give it ago when I get home from work. Does it matter if I use the switch on the passenger side or the switch on the drivers side?
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
What year is your car ? |
It's a 2007 tdv8 |
As has already been said, to recalibrate the window position, close the window and keep the switch pressed for one second.
Thanks all. Just got home put the window down then up as far as it would go then held the up button down for 2 seconds then the window went up then little bit more and closed |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Here is an alternative solution! http://www.rrsport.co.uk/forum/topic46827.html
