Home > Technical > Location of front heated windscreen fuses
shepp
Hello all
I am trying to locate the fuses/relays for my 2012 front windscreen. The right side is not working at all. The connector to the window has no power. checked the hand book and it has no reference to the fuses. Also tried a search on the site to no avail.
Help would be greatly appreciated
Shepp MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #518231 Sun Feb 19 2017 3:35pm
try looking at the symbols on the lid in the fusebox under the bonnet.
It only has 1 relay so won't be that
On early models its fuse 15 R & 18 L
Post #518256 Sun Feb 19 2017 6:00pm
shepp
Cheers Andy, the fuses are different on the MY12. I think I may have identified them but need to confirm so I can do some accurate testing.
I think they are the high capacity slow blow square fuse, looks a bit like a relay
Regards
Shepp MY12 RRS HSE
Gone 90
Gone s2000
Post #518286 Sun Feb 19 2017 8:41pm
They are in a bank of six fuse locations to the rear and slightly left, sort of pink square 30amp rated fuse position 2 is right hand side and six is left hand side.
There is also as L/R service bulletin about fitting a different type of fuse as it is a know issue to MY12/13 cars blowing these fuses, I think I have a copy somewhere which I will try and find, as I had the same issue and the local dealer wanted to fit a new screen for me at �640,00 after saying they had checked everything when it was a blown �1.25p fuse.
Post #518293 Sun Feb 19 2017 9:37pm
shepp
Cheers Col, I suspect it was the J type fuses, but they are both in tact, so I suspect the relay may be faulty. I have no voltage at the right hand window connector. If you have the TSB, that would be excellent.
Regards
Ben MY12 RRS HSE
Gone 90
Gone s2000
Post #518295 Sun Feb 19 2017 9:42pm
turn the heater on and see if there is voltage present at the fuses
Post #518297 Sun Feb 19 2017 9:51pm
shepp
There is power at both the fuses so suspect it may be the relay. I don't have any schematics to see how the power is delivered to the screen. MY12 RRS HSE
Gone 90
Gone s2000
Post #518299 Sun Feb 19 2017 10:17pm
PM me a email address and I will send you one as pdf file.
Post #518301 Sun Feb 19 2017 10:34pm
Bill Portland
My driver's side heated screen is not working. Did this thread resolve whether each side is fixed separately?
Any advice would be appreciated Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #530467 Sun Jul 16 2017 2:10pm
shepp
Hello Bill
Fixed mine with a new screen, paid for by the garage. If yours is not working remove the interior a pillar trim and the connectors are easily accessible to check with a multi meter.
Only a couple of the heated elements worked on mine due to a poorly fitted screen.
Shepp MY12 RRS HSE
Gone 90
Gone s2000
Post #530469 Sun Jul 16 2017 2:18pm
Bill Portland
Thanks, how does the pillar trim come off? Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #530692 Tue Jul 18 2017 10:32pm
Gently prise out the Oval Airbag Grommet at top of pillar, underneath is a torx headed screw can't remember if it's 20 or 25, remove it, should stay in the trim as it's held in place by the plastic. The just gently pull out from the top as has a small plastic locating lug at the top and lift upwards out of locating recess at the bottom.
Post #530695 Tue Jul 18 2017 11:10pm
Bill Portland
Thanks for that, I'll have a go this evening Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #530725 Wed Jul 19 2017 12:01pm
Bill Portland
It seems that the Incredible Hulk is employed on the LR assembly line and is responsible for putting in the torx screws mentioned above. They're solid!
Col, do you have that schematic wiring diagram that you mentioned earlier? I'd like to have a rummage around the fuses and relays before I strip the torx screw heads completely. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #531176 Tue Jul 25 2017 12:57pm
I normally use a 3/8" ratchet drive on them and its easy
Post #531203 Tue Jul 25 2017 8:49pm
