![]() | Home > Technical > Location of front heated windscreen fuses |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Adrian,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Pillars should remove. Maybe it got hot.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
The fuses are very stiff, but you can also pop the top off and check for continuity from one half to the other. MY12 RRS HSE
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 393 ![]() ![]() ![]() |
Just pulled it out with a bit of a pull and wiggle.
I'd get the side trim off before you replace the fuse and disconnect the windscreen if easy.
Halfords only stock the full size ones, not the low profile ones. I've ordered a couple from Rimmer's.
