Home > In Car Electronics > SAT NAV Display backlight
My SAT NAV display has gone very dim whether the external lights are on or off.
It did flicker a bit before it dimmed Crying or Very sad
Can I replace just the backlight somehow?
Thank you
Post #517830 Tue Feb 14 2017 8:03pm
Johnski
It could be just dry joints if intermittent, but a real sod to get out and check/repair and costs a lot if you pay. May need a new light source LED if edge lit or LCD or plain old tube backlight all depending on model Year fitted. John
Post #517841 Tue Feb 14 2017 10:24pm
Socast
Is it that the perspex in front of the ambient light sensor dirty ?
Try shining a torch on it to see if it's working.
Post #517876 Wed Feb 15 2017 10:05am
Where is the AL sensor ?
This morning it seams to be bright again Confused
I had the CTEK charger on it over night.
Post #517888 Wed Feb 15 2017 12:02pm
Socast
little clear blob at the bottom of the rev counter. Thumbs Up
Post #517892 Wed Feb 15 2017 12:14pm
Cool didn't know it was there.
Yes the ALS is functioning ATM, and the display is at the correct brightness.
Will check the sensor next time I have a dim display.
Post #517900 Wed Feb 15 2017 5:12pm
scarey
you normally get a dim display when its cold and the battery power is prioritised by other ecus..if you stop and restart the display should go back to normal brightness....
Post #517918 Wed Feb 15 2017 9:05pm
