Home > Technical > EGR circuit code
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
EGR circuit code
Does anyone know if fault code P0489 is a code for either side or "A" off side ? Confused
Post #516791 Sat Feb 04 2017 9:42pm
Disco_Mikey
Doesn't matter. Blank them Wink Thumbs Up
Post #516792 Sat Feb 04 2017 9:59pm
m3nutter
Does it keep the Eml on if you do ? 2007 tdv6 ?
Post #516798 Sat Feb 04 2017 11:02pm
Disco_Mikey
Yes, but easily resolved with a software patch Thumbs Up
Post #516806 Sat Feb 04 2017 11:36pm
m3nutter
How do I ( you Smile ) do that when I'm a million miles from you ?
Very Happy
Post #516823 Sun Feb 05 2017 12:15am
Disco_Mikey
Post #516828 Sun Feb 05 2017 8:31am
m3nutter
Ok cheers Mike I will give them a ring
Nick
Post #516830 Sun Feb 05 2017 8:46am
m3nutter
Hi Mikey I text Paul and he can't do it because he says he doesn't have right equipment.?
Any one else close ish ?
Also, if I blank inlets and valves off, and clear the fault p0489 (I have a reader which will do that ) , might it be ok to drive even though it may put the mil light on?
Nick
Also, my battery is poor, down at 11.88 volts this morning, could this be the problem, ecu messing about
Post #516835 Sun Feb 05 2017 10:10am
Disco_Mikey
I have sent Ian a message (Bodsy) and a link. Not sure if he gets down as far as yourself
Sure he will reply in due course Thumbs Up
Battery is not great, but won't be causing your issue
Post #516837 Sun Feb 05 2017 10:41am
m3nutter
Thumbs Up cheers
Post #516838 Sun Feb 05 2017 10:51am
Bodsy
Site Sponsor
Thanks Mike,
Yes, I can sort this out for you. Will drop you a message. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #516840 Sun Feb 05 2017 11:27am
m3nutter
Cheers Ian just responded to your pm
Nick
Post #516842 Sun Feb 05 2017 11:39am
