Home > Maintenance & Modifications > west4x4 anyone used them?
delta351
Hi all has anyone used these guys before?
http://www.west4x4.co.uk/
I'm going to ask them to change my front disks, pads, replace my power streering pump as the bearings are very noisey also over hall my supercharger snout as the bearing in the are also noisy.
after typing out that list it sounds like I'm going to spend Shocked 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #516695 Fri Feb 03 2017 11:56pm
Buckster
Only ever heard good stuff about them, but never used Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #516707 Sat Feb 04 2017 3:38am
DrRob
Highly regarded over on sister site Disco3.co.uk....do a search on there Thumbs Up
Work colleague uses them and local cafe owner - all very pleased. He knows these vehicles inside out Thumbs Up Visitor from fullfatrr.com
Post #516716 Sat Feb 04 2017 9:51am
DrRob
PS we should organise a Hampshire pub meet Thumbs Up Visitor from fullfatrr.com
Post #516717 Sat Feb 04 2017 9:53am
delta351
Thank you
Thank you for all your reply's I will give them a call on Monday. Very Happy Very Happy Very Happy 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #516784 Sat Feb 04 2017 7:57pm
delta351
Sounds good DrRob it will take me a few weeks to get mine sorted...
Thumbs Up 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #516785 Sat Feb 04 2017 7:58pm
Buckster
What a great idea Rob, its been a while! Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #516788 Sat Feb 04 2017 9:10pm
DrRob
We could organise a RR Sport and Disco3 open meet at "you know where" on the side field (landlord is a mate of mine) Thumbs Up Visitor from fullfatrr.com
Post #516789 Sat Feb 04 2017 9:20pm
delta351
I'm picking my RRS up from http://www.west4x4.co.uk/ tomorrow morning after having a new dynamic pump and a recon super charger snout from http://www.powerhouse.uk/
cant wait to get it back Thumbs Up 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #520941 Tue Mar 14 2017 10:12pm
DrRob
All fixed? Visitor from fullfatrr.com
Post #520982 Wed Mar 15 2017 11:14am
delta351
Hi DrRob, mmm well the super charger snout is all good, the dynamic pump was changed but there is still a whirring noise
not as bad as before but you still can hear it. I would like to have a listen to another RRS super charged just to compare, it could be the super charger fins. Shocked 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521059 Thu Mar 16 2017 12:04am
Stripesgixxer
Delta351 am just up road from you in Wickham if you want to come and listen to mine
Post #521063 Thu Mar 16 2017 8:11am
Socast
I've had the same issue with mine, noisey ace pump.
So far I've spent roughly 2500 trying to fix it, I've replaced the pump, the reservoir, the pipe from reservoir to pump, the pipe that leads from pump to valve block, the valve block, the alternator and both idler pulleys that are close to it.
I've had the system flushed as well, it passes all tests and works as it should but it whines like a Censored
I had it into landrover yesterday and they told me it's fine and didn't think it was loud so wouldn't warranty the pump. They happened to have another SC there at the time so I asked them to fire that up to compare the two, funnily enough that one made the same whine so begrudgingly I had to admit defeat, however I'm not convinced that it should be as loud as it is.
At this point though I'm lost as to how I can fix the issue, I've replaced everything, had all updates applied and still no dice.
And before anyone mentions it, it isn't the charger, I've had remote ears on it and the sound is coming from the pump, not only that but when I swapped the pump it was silent until the oil bled through, as soon as the oil hit the pump the whining started again. While the system self bleeds you can run a program that does a more proactive bleed, this too has been done a few times.
Post #521068 Thu Mar 16 2017 9:38am
delta351
Pump
Hi Socast, I'm total with you I've just spent 1350 on getting my pump, filters & fluid changed
I am now going to join you Banging Head
hope fully someone else on here has had the same problem as us. 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521118 Thu Mar 16 2017 9:03pm
Stripesgixxer
Mark cant PM (should be able to after this) let us know if you still want a listen
Post #522924 Wed Apr 05 2017 11:10am
