![]() | Home > General > 2005 rrs 1st to 2nd gear auto |
Has the car got paddle shift & if so you didn't catch one of the paddles by mistake as a few have done this in the past.
This may sound crazy but it is well known that faulty brake light bulbs can cause that.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5105 ![]() ![]() ![]() |
yeah check brake light bulbs
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
The other thing to check is whether your tyres are matched across the axles. ie if you have different type tyres, or a big difference in the wear between them, this can prevent the gearbox from up-shifting, as it thinks the car is cornering. (Though this usually occurs when you get tho 4th, not 1st or 2nd).
