![]() | Home > Maintenance & Modifications > compressor |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
That doesn't right, not at all. Even when mine was leaking it wasn't making much noise. I've rebuilt it myself replacing the piston and guides and it's still very quiet. Think I would be taking it back with concerns if I were you. Easiest way to hear it is open pessenger front door set it in off road height get down near the compressor and then shut the door it will then inflate the suspension to lift the car. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
The compressor can be quite loud and will be intermitant as it keeps the air at a preset pressure. It shouldn't sound rattly though.
aspen Member Since: 30 Jan 2017 Location: Sheffield Posts: 12 ![]() ![]() ![]() |
thank you for the input guys,
Nope.
Macca Member Since: 03 Oct 2016 Location: Nottinghamshire Posts: 17 ![]() ![]() ![]() |
I would take it back. It may be that the new compressor was mounted incorrectly causing reverberation through the body or indeed it has a fault. D3 TDV6 SE auto 2006
The compressor is fixed to the chassis with three of those dodgy sprung steel 'captive nut' things. They corrode badly and one of them is notoriously hard to get the bolt into.
I'm going to check all of these things out tomorrow.
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 ![]() ![]() ![]() |
Diesel engine oil usually gets pretty black quickly, especially when you have EGR.
Very bad idea to add ATF or any other proprietary 'snake oil additives' to your engine oil. Some of the detergent will remain even after the oil is changed and have a deleterious effect on the lubricating properties of the engine oil. At worst it may dislodge some oil sludge from a place where it is not doing any harm and allow it to move and block an oilway. Yes - we know many garages routinely stick some rubbish 'oil flush' in your engine at every service. IT IS JUST A SCAM to get another £5 out of you and these garages should be ashamed of themselves. Just use high quality oil of the correct specification and an original Land Rover filter, (fit it properly with the spigot located in the hole or your engine will have a catastrophic failure). Change the oil every 6k miles or so. 2008 MY Java Black TDV8 HSE ![]() |
It does seam pointless on these cars |
im trying to get rid if this tick tick tick sound from the engine. (see other post) hence thinking about the flush.
