![]() | Home > Technical > Stupid Q - boot opening RRS 2007 |
Only thing is to ensure the boot is fully closed.
Milblunder Member Since: 28 Jan 2017 Location: Berkshire Posts: 24 ![]() ![]() |
I'm certain it's closed but will have another go tomorrow....cross fingers. When driving though boot not showing up as open on the dash... |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Welcome to 2nd hand RRS's ![]() I had the same issue with mine after I bought. One of 2 things - either a loose/corroded wire to the upper tailgate release or a knackered release. Water comes down the back screen and into that area like billy-o and as a result this is quite a well known issue. Take the panel off above the release switch and check that the wire is making a good connection and if that is still not working, then replace the switch with a new one - available on eBay and I think Mondeo ones are similarly compatible? Simple/cheap fix |
Cheers bud will check...washed car today (poor initial valet) no water ran down but will check |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I have the same issue with mine. In my case a faulty, and presumably corroded, switch. If you squeeze the tailgate switch tightly, adjusting the precise point you are squeezing, and also repeat a number if times, you may get it to start working again. Mine did that and as I don't use it too much I'm just waiting for some warmer weather before I have a go at changing it. Robin
Yeah good point about the switch. |
Pressed switch loads of time in various places still no joy....any ideas as to how to get to check it.....having trouble removing the trim....vids and threads suggest you have to have the top open to remove trim....is there another way to access the switch/cable? |
switch comes out easy. Just use a flat blade screwdriver and leaver at one edge.
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
My dads was like this when he bought it, his was a broken wire at the top of the tail gate. |
