Home > Technical > intermittent starting problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
Does the engine turn over ?
Thu Jan 26 2017 10:38pm |
Shokbox Uk Member Since: 26 Jan 2017 Location: Derbyshire Posts: 5 |
Hi
Thu Jan 26 2017 10:41pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
What do you mean by dead ? No ign lights on dash, or the starter doesn't engaged and turn the engine over, ticking noise and flickering dash lights or something else. We need more detailed info.
Thu Jan 26 2017 10:43pm |
central locking works, but the dash doesn't fully light up, no ticking that i can recall, but will listen out for it next time, engine doesn't turn over. i push the start button and nothing happens. i leave it for 10-15 mins and vehicle starts without a problem. I'm pretty sure battery is fine, but i guess its worth following the procedure you recommend |
Thu Jan 26 2017 10:49pm |
I seem to remember a chap having a similar issue, for him it was the earth strap from the starter to the body that was hanging off.
Fri Jan 27 2017 12:09pm |
Shokbox UK - Just in case it helps have a look at this thread:
Fri Jan 27 2017 4:54pm |
Thank you for the heads up, ill let you know what happens |
Mon Jan 30 2017 8:18pm |
