![]() | Home > In Car Electronics > Upgraded audio install completed |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Having followed the incar head unit thread and asked loads of questions I completed my install over the weekend.
Only issue is old bluetooth module trying to connect to my phone so need to removed from MOST circuit. have orderd a MOST loop as below to complete circuit
Yes the connections are under seat but the InCarTec loom already has two pink flying leads which connect via the multiplug. I simply extended those speaker cables and included them in the speaker loom from under seat back to head unit and then connected to amp. You could put amp under set but then you still need to get RCA and remote cable down there anyway so a 50/50 decision and I like the neatness on where the amp fits by glovebox behind the panel
Forgot to mention USB lead into glovebox with a 32GB data stick with tunes on
Oh and the fibre optic loop just turned up Fitted
Working Nav screen as a result ![]()
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
Looks good, do you still have sat nav audio? |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
Nice install did you have the Logic 7 system previously, if so are you still using all of the speakers and the original amp. Life's too short to drive boring cars !
No but then I never used the voice guidance part so not an issue for me and prefer google maps on phone as more accurate anyway TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Not Logic 7 just standard Harmon Kardon so bass and tweeter in 4 doors powered by head unit and sub in boot lid powered by amp TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Makes sense, I regard the built in sat nav as a novelty not something useful. Do you definitely have sound coming out of the tweeters? I've seen some posts saying that after upgrading it only comes out of the bigger speakers. |
Yep definitely sound from tweeters as on same feed to doors as main speakers
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
Thanks Rob, I've just ordered my IncarTec fitting kit. I may have questions later! 2006 RR Sport Supercharged Love this car
Thanks, I assume its the logic7 that has the seperate twweter/mid and bass circuits in the door shown on page 3 of those diagrams?
No problem what head unit have you gone for? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
There is a Logic 7 solution now available
I haven't as of yet Rob I'm looking around at the mo. 2006 RR Sport Supercharged Love this car 2009 BMW 335D GONE 2008 VW R32 GONE 1999 RR SE GONE 1994 RR HSE GONE 2001 VW V5 GONE |
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 ![]() ![]() |
Just the kind of thing I'm looking for, could you post links etc?
