Home > Maintenance & Modifications > FBH update |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
So,are you saying that the fbh will not just shut off if it detects low voltage but actually prevents itself from starting again until unlocked by the garage? Robin
Mon Jan 23 2017 5:49pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
after 3 attempts it locks out, i had my alternator go down a little while back I'm hoping it all locked out then I've put a new battery on so just have to keep watch. can't see why it wouldn't try to start after the vehicle is running and alternator is charging |
Mon Jan 23 2017 5:54pm |
Hmm. I didn't know that. It seems a bit strange but some LR developer obviously thought its better to have no fbh but enough battery to start the car. However as you say once it's running, what's the problem?
Mon Jan 23 2017 6:35pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
They dont lock out because of low voltage, if the battery is low they just wont start. What will lock them out is low fuel, if you have less than a 1/4 tank it will not run, it goes in to lock out mode to save fuel after three failed starts.
Mon Jan 23 2017 11:22pm |
Less than 1/4 of tank oh right I thought low fuel was meant by if the light was on, when Bodsy unlocked first time is was because of low fuel this time the garage said it was locked out due to low voltage ??? |
Tue Jan 24 2017 3:30am |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
How does the regular Joe know if his FBH has locked itself into cryostasis?
Tue Jan 24 2017 7:28am |
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 |
Mine was working the other day and I was just over reserve, so not sure about this not working under 1/4 tank. 2012 RRS SDV6 2014 BMW 320d X-Drive Touring 1999 VW Polo stage rally car |
Wed Jan 25 2017 10:45pm |
