![]() | Home > Maintenance & Modifications > Help changing rear discs |
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 ![]() ![]() ![]() |
Hit a problem.
Update, so i just put in to N and manually turned road wheel.
Thanks buddy but i have already done it.. its an easy job, the actual removing of the dics and pads etc
One thing i did do was to adjust the small hex key tention bolt in the hub, was this needed if keeping the same shoes? '06 RRS Supercharged Cairns Blue |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 ![]() ![]() ![]() |
Have you adjusted the brake shoes up ok? Test it while driving slowly, my EPB locks the rear wheels at walking pace |
Yep adjusted them fine, not had a chance to do a proper road test yet. Will do it when i di the bedding in procedure '06 RRS Supercharged Cairns Blue |
I dint bother bedding in as I didn't fit new shoes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
I don't think I could get mine into service mode either.
So what did you do there Andy? What is the pin doing ?? '06 RRS Supercharged Cairns Blue |
Drilled a hole which allows the shift lock to be released without the battery connected or putting the ignition on and pressing the brake.
