Home > Maintenance & Modifications > Help changing rear discs |
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 |
Hit a problem.
Sat Jan 21 2017 1:17pm |
Update, so i just put in to N and manually turned road wheel.
Sat Jan 21 2017 4:46pm |
Thanks buddy but i have already done it.. its an easy job, the actual removing of the dics and pads etc
Sat Jan 21 2017 4:50pm |
One thing i did do was to adjust the small hex key tention bolt in the hub, was this needed if keeping the same shoes? '06 RRS Supercharged Cairns Blue |
Sat Jan 21 2017 4:54pm |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 |
Have you adjusted the brake shoes up ok? Test it while driving slowly, my EPB locks the rear wheels at walking pace |
Yep adjusted them fine, not had a chance to do a proper road test yet. Will do it when i di the bedding in procedure '06 RRS Supercharged Cairns Blue |
Sat Jan 21 2017 4:56pm |
I dint bother bedding in as I didn't fit new shoes |
Sat Jan 21 2017 5:10pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
I don't think I could get mine into service mode either.
Sat Jan 21 2017 5:14pm |
So what did you do there Andy? What is the pin doing ?? '06 RRS Supercharged Cairns Blue |
Sat Jan 21 2017 10:41pm |
Drilled a hole which allows the shift lock to be released without the battery connected or putting the ignition on and pressing the brake.
Sun Jan 22 2017 12:19pm |
