Home > Tips & Tricks > Access Height - Set to Automatically work?
Page 3 of 3 <123
Eaters
I try to use everything occasionally just to make sure it's still working and to keep it freed up.
Which would you rather do? Take to a garage for them to tell you it's gunged up and broken through lack of use? Or take it to a garage who tell you it's worn out? Might as well have the use of all your toys Smile Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #514313 Thu Jan 12 2017 11:19pm
scrumps
DrRob wrote:
No ECON button in mine. 2012 car.
Turn off "Auto". It turns climate into a conventional heater , stops using the compressor and reduces the engine load.
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #515138 Thu Jan 19 2017 10:53pm
Jaggs
Sure I read somewhere that you are best selecting access height before you come to a complete stop to preserve tyres and suspension, as there is some side ways pressure on the wheels as the car drops. Nanocom Evo
Post #515169 Fri Jan 20 2017 10:03am
Beancounter_74 wrote:
I have got into the habit of pressing the down arrow as I slow down to park. That way, the car is pretty much lowered before or just a little after I switch off the engine. I do like the idea though of having a menu set option that is your prefered parking height Idea
+1
I also lower my D4 when I have parked. This, together with gathering my wallet, keys, etc., lets the turbo cool down a bit before I switch off. Thumbs Up --
Post #515176 Fri Jan 20 2017 11:00am
Yes it is less stressful on the handbrake, gearbox parking claw etc. etc.
Post #515181 Fri Jan 20 2017 11:52am
NickyN
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
I may be going mad but having stopped the car and forgotten to lower to access height for the dog, when I press the lower button with the ignition on ( engine not running ). The car actually rises.
Starting the engine thereafter, and selecting access height - the car lowers as expected.
Very different from our D4.
Has anybody else noticed this?
2015 RRS.
Post updated 1/7/19
Had a series of suspension faults / IEB braking not avaiable.
LR Assist attended and diagnosed inability of gallery to vent on compressor. A small sintered bronze silencer on the compressor was blocked. It was replaced with a modified one with a hole drilled in the centre.
The car now lowers rather than rises going into access mode. I was not going mad after all! ---
Nick
LR History:
RR Vogue 1984
300TDI Disco
Series III (shed on wheels)
RR Vogue SE Auto 1995 (LPG)
Disco TD5ES 2002
2004 D3 HSE with spots and shiny bits and General AT's.
2013 D4 HSE Luxury
2015 Corris Grey RRS Autobiography
Post #582417 Fri Jun 14 2019 4:08pm
Tallchap
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I am a newbie, but I believe the LR button on the key can be coded to several features - one of which can be to lower the suspension to access height, or to raise it. Once you have ‘coded’ the button, you then press and hold the LR button and lock button to raise, or LR button and unlock button to lower.
As I am new to my 2008 RRS TDV8, I have just read the manual cover to cover - page 38 if you’re interested Thumbs Up
Cheers,
TC.
Post #588620 Tue Oct 15 2019 8:24am
Tallchap
Sorry, page 39
Post #588621 Tue Oct 15 2019 8:26am
nil07
I believe there is a button under the steering column which does this if it either pressed or not ...can’t remember which N
E46 M3
X6
2015 RRS HSE dynamic
2018 RRS Autobiography
2019 SVR
Post #588631 Tue Oct 15 2019 11:59am
Page 3 of 3 <123
